41 - 60 of 409 Posts
Discussion starter · #41 ·
Steve-
Wow! Awesome work on 164L.
What about a/c system, looking at a car that a/c is not working and need recharge.
I'm in California.
Mark
What kind/year of car? R12 or has it been converted to 134a already?
Discussion starter · #43 · (Edited)
Removing 164 wiper motor before changing blower motor
http://www.alfabb.com/bb/forums/164-168-1991-1995/165845-w-s-wiper-assembly-removal.html
With wiper motor out much more room to get blower motor and heater core out.
Not sure if we spelled out removal procedure before or not but not to hard to do. Remove black caps on wiper arm nuts, remove nuts, washers and arms. remove black caps on bolts near arm pivots, remove bolts/washers, remove metal bracket over right side pivot point, then remove hidden bolt above motor holding motor frame to ****pit wall.
You have to loosen round connector, remove connector round nut, slip out of metal bracket. Remove two nuts holding bracket to floor behind false firewall. remove black cover over blower motor relay.
Move wiper motor some and disconnect wiring connector to it and manipulate assembly until you work it out of car.
Discussion starter · #44 ·
Alfa 164 Front Axles CV Boots Info
Alfa 164 Axle Boots Cross-Reference
Alfa 164 Outer Axle CV Boot 60556609
Raybestos 5451337 and Beck Arnley 1032146
The following use same outer Boot:
ALFA ROMEO 164 1991
ALFA ROMEO 164 L (1991 - 1993)
ALFA ROMEO 164 LS (1994 - 1995)
ALFA ROMEO 164 QUADRIFOGLIO (1994 - 1995)
ALFA ROMEO 164 SPORT (1991 - 1993)
AUDI 200 (1989 - 1991)
AUDI 200 QUATTRO (1989 - 1990)
AUDI 200 QUATTRO 20V 1991
AUDI 4000 QUATTRO S (1984 - 1985)
AUDI 4000 S 1985
AUDI 5000 (1982 - 1985)
AUDI 5000 CS (1986 - 1988)
AUDI 5000 QUATTRO CS (1986 - 1988)
AUDI 5000 S 1980
AUDI 5000 S TURBO (1984 - 1985)
AUDI 5000 TURBO (1981 - 1983)
AUDI QUATTRO 1985
SAAB 9000 AERO (1994 - 1997)
SAAB 9000 CD 1994
SAAB 9000 CDE 1994
SAAB 9000 CS (1994 - 1997)
SAAB 9000 CSE 1994
SAAB 9000 CSE TURBO (1995 - 1998)
VOLVO 850 (1994 - 1996)
VOLVO 850 R 1997
VOLVO 850 T5 1997
VOLVO 850 T5 R 1995
VOLVO 850 TURBO (1995 - 1996)
VOLVO C70 1998
VOLVO S70 1998
VOLVO S70 GLT 1998
VOLVO V70 T5 1998
Inner CV Axle Boot 60510352
Beck/Arnley 1032147
ALFA ROMEO 164 1991
AUDI 100 (1989 - 1991)
AUDI 100 E 1989
AUDI 100 QUATTRO (1989 - 1991)
AUDI 100 QUATTRO CS (1992 - 1994)
AUDI 200 QUATTRO 10V 1991
AUDI 4000 QUATTRO CS (1986 - 1987)
AUDI 5000 (1980 - 1985)
AUDI 5000 QUATTRO S (1987 - 1988)
AUDI 5000 S (1980 - 1988)
AUDI 80 1991
AUDI 90 (1988 - 1991)
AUDI A4 (1997 - 2001)
AUDI A4 QUATTRO (1997 - 2005)
AUDI A4 QUATTRO AVANT (1998 - 2005)
AUDI A4 QUATTRO CABRIOLET (2004 - 2005)
AUDI A6 QUATTRO (1995 - 2004)
AUDI A6 QUATTRO AVANT (1999 - 2004)
AUDI A8 QUATTRO (1997 - 2003)
AUDI A8 QUATTRO L (2001 - 2003)
AUDI ALLROAD QUATTRO (2001 - 2005)
AUDI QUATTRO (1983 - 1985)
AUDI RS6 (2003 - 2004)
AUDI S4 (2000 - 2005)
AUDI S4 AVANT (2001 - 2005)
AUDI S4 CABRIOLET (2004 - 2005)
AUDI S6 (1995 - 1997)
AUDI S6 AVANT (2002 - 2003)
AUDI S8 (2001 - 2003)
AUDI TT QUATTRO (2000 - 2004)
AUDI V8 QUATTRO 32V (1990 - 1994)
VOLKSWAGEN BEETLE TURBO S (2002 - 2004)
VOLKSWAGEN EUROVAN (1993 - 2003)
VOLKSWAGEN EUROVAN CAMPER (1995 - 1997)
VOLKSWAGEN EUROVAN CL 1993
VOLKSWAGEN EUROVAN CV (1993 - 1994)
VOLKSWAGEN EUROVAN GL 1993
VOLKSWAGEN EUROVAN GLS 1995
VOLKSWAGEN EUROVAN MV 1993
VOLKSWAGEN EUROVAN TRANSPORT 1995
VOLKSWAGEN GOLF GTI (2002 - 2003)
VOLKSWAGEN PASSAT (1999 - 2002)
VOLKSWAGEN PASSAT 4 MOTION (2003 - 2005)
VOLKSWAGEN PASSAT GLS 1998
VOLKSWAGEN PASSAT GLS 4 MOTION 2002
VOLKSWAGEN PASSAT GLX 4 MOTION 2002
Discussion starter · #48 ·
Discussion starter · #49 · (Edited)
Alfa 164 Tech Bulletin 40.93.01 Wiring Diagram Corrections - 164S Suspension
Looks like file is to big to load will try to parse.
Discussion starter · #50 · (Edited)
I have been reading the links Alfisto Steve has posted for Timing belt replacemnt on 2.5 Alfas, it is very helpfull Thank you. One question for you; in Rick's Cam timing pdf template, it states to use 8"x14" paper at 100% scale setting for printing. All I can locate is legal sizec 8.5" x 14" is than the size he is refering to? I am trying to get this
right the first time.
Thank you for the help.
Discussion starter · #53 ·
I guess I made a typo so 8.5 x 14 or two 8.5 x 11 pieces taped together.
Discussion starter · #55 · (Edited)
Looking for break light wire diagram for 164LS.
See page 462 1994 wiring manual. It is a fold out page so pretty hard for me to copy. If you own a 164 you need to get a CarDisc International Ltd. - Alfa Romeo Manuals, Giulietta Manuals, Giulia Manuals, GTV Manuals, Spider Manuals, American Austin & American Bantam DVD if you don't have two volume 900 pages each shop and electrical manuals. If you have a 95 DVD has those manuals, too and much more.
What is your problem no brake lights and if A/T can't get out of park unless you push manual overide? If so cut out little rectangle shunt box in B/L switch wiring at switch and splice wires together and see if you now get brake lights.
Discussion starter · #56 · (Edited)
Alfa 164 V6 exhaust gasket part numbers
Alfa 164 V6 exhaust gasket part numbers going from engine heads to back of car:
60506636 ex manifold to head stamped copper or steel gasket 164 12v V6 (6 ea)
60573536 ex manifold to head square double layered steel gasket 24v (6 ea)
60510306 ex pipe to manifold thin metal layer sandwich style with insulation center gasket 164B/L/S 12v (2 each)
60654239 gasket ex pipe to manifold 164LS/Q 24v (2 each)
60510307 two pipe copper cat inlet copper gasket 164B/L
60805010 or 60571802 two pipe cat inlet gasket 164S One number one piece gasket and other one is two separate gaskets I think.
60573540 front cat inlet gasket 164LS/Q 24v (2 each)
60510816 3-bolt hole rear cat outlet gasket 164B/L (usually copper but maybe composite with flame ring).
82473321 R/H cat outlet copper gasket 164S
82420455 L/H cat outlet steel sealing ring 164S
82407147 sealing steel ring rear muffler to center muffler 164 all and 24v rear cat outlet (1 ea 12v and 2 ea 24v).
Here is thread that started all of this: http://www.alfabb.com/bb/forums/164-168-1991-1995/54218-exhaust-gasket.html
Discussion starter · #57 ·
I added remote starter wire to my Alfa 164 today.
I added remote starter wire to my Black Beauty today. I unwrapped BLACK TAPE off the engine wiring harness on the engine side of the false firewall.
It is the harness with rubber ring that pushes into round hole in false firewall.
There are two black wires in harness and the pin 1 in G151 connector power wire to starter solenoid pin 50 is the larger of the two black wires It is the 2.5mm (AWG 12) wire. I used a Tyco AMP splice tap yellow connector for 12-10 size wire to add a 12 AWG wire pigtail. I can now hook my push button remote start cables to this pigtail and power side of 40A cooling fan fuse bar terminal board.
I will be able to do compression test, etc without having to go in the ****pit and turning on the key and turning key to start position.
This remote start feature also will bepass chassis wiring to starter is something fails besides starter.
Discussion starter · #58 · (Edited)
1991- 93 Alfa 164L and 164S USA ABS Bosch system components
1991- 93 Alfa 164L and 164S USA ABS Bosch system components:
Takes Torx 15 screw driver tip to remove pump cover and harness hold down screws
ECU 0 265 100 051
ABS Harness Alfa 90557 953.04.04.90
ABS Pump 0 265 201 016 with two relays Blue 0 332 204 153 and black 0 332 002 174
Chassis relay 10A 0 332 512 009 and chassis free fuse holder 10A both located to right of glove box under dash panel under a/c outlet near door.
R/R sensor/cable 0265001073 60508251
L/R sensor/cable 0265001074 60508250
R/F sensor/cable 0265001251 60545850
L/F sensor cable 0265001250 60545849
Discussion starter · #59 · (Edited)
91-93 164 12v ABS sensor cables
Bosch # Alfa #
Discussion starter · #60 · (Edited)
