Alfisto Steve's New Rule 164 V6 owners please read now
10K views 19 replies 9 participants last post by  Michael Smith
#1 · (Edited)
01-Engine-12v Cam Timing Alfisto Steve's New Rule 164 V6 owners please read now
Alfisto Steve's New Rule - Always verify cam timing on 164 12v V6 engine as first step when troubleshooting a non-starting or running issue.
Note: Also when posting a question about your Alfa. Goats has wisely requested you state what model, year and engine you have in your Alfa.
Can apply on GTV6 and Milano V6 engine, too.
If your 164 12v V6 starter turns engine over but it does not start, VERIFY CAM TIMING before you try anything else!
Now everybody print off Rick's 12v V6 timing template laminate it and use it.
Cam timing pdf template. Print it off on 8 1/2 x14 paper at 100% scale setting. This is Rick's Template he posted for us to use.
http://www.alfabb.com/bb/forums/att...forums/attachments/164-168-1991-1995/66906d1179330802-cam-timing-cam-timing.pdf
Some pictures of engine in the car and using template on cams and crank pulley set at TDC and new style tensioner pointer just below reference mark.
http://www.alfabb.com/bb/forums/1057872-post10.html
Some clearer pictures of cam timing on an engine out of car for better clarity and trying to show crank pulley top dead center marks:
http://www.alfabb.com/bb/forums/758442-post3.html
http://www.alfabb.com/bb/forums/4897241-post6.html
Keep track of your timing belt change both mileage and date on your timing belt cover:
see this picture: http://www.alfabb.com/bb/forums/5124433-post84.html
#2 ·
Glad I have the lowly 4 banger, I don't care for rules as a general rule. Ciao, chris
#4 ·
Well this is one rule if broken may not really matter because engine already may have bent valves on rear head but it will allow you to verify why the engine won't start before you spend needless hours troubleshooting fuel and air system to no avail.
#10 ·
Easier than taking the pesky fender liner out and ensuring the floaty thingy is still doing its thing eh Jason....
One of your engines Mr Steve? Ciao, chris
#14 · (Edited)
I've been following the no start thread, just was tossing something out there to see how much it stuck. I kinda thought that was where you were going. Just didn't want to stir the pot as it were since it seems to me, some are a wee bit cranky of late. Pun intended. Ciao, chris
#15 ·
Sorry for seeming a wee bit cranky, but I expect others might be a wee bit cranky too if they were in my situation, thinking you've finally at last solved the problem after hours and hours of troubleshooting and money spent, and are about to be driving your Alfa again, and then finding out it's worse than you'd imagined.
A very valuable and expensive lesson that I've unfortunately learned the hard way.
Most of the troubleshooting procedures start first with checking the fuses, then the fuel relays, then jumping the relay, then checking fuel pressure, then checking for spark, checking the grounds, etc, all the time you're cranking away just aggravating the situation, wearing out your starter and wasting time and money when none of that matters if your timing is off.
Oh well, just like in aviation where every new rule is written in blood or bent metal, this one was fortunately only written in bent valves.
#16 ·
Please if you are upset that I used cranky, rest assured this was not directed at you. If you took it as such, I apologize. On some of the other threads about should I or should I not sell my Alfetta and one Mr Chaz got caught up in, responses have been not so civil. Having read thru your notes and such, I find your reaction to be better than mine would have been for sure. Ciao, chris
#17 ·
I'm picking up a "ran when parked" 164 L shortly. Looks like this will be a must before even beginning to start it.
#20 ·
Note the sharp cornered edges of the cambelt teeth. This is the cause of cambelt failure. Later research showed the intuitive design which looks like it would "hold" into the cam drive gears better was incorrect. The sharp corners fatigue crack, teeth strip and bang goes your engine.
I've seen the cambelt from my later design Audi V6 which has softly rounded teeth and matching sockets in the cam drives. Those belts are rated for 100,000 miles (160,000 km) with no predicted service life limit.
In addition to verifying cam timing the opportunity should be taken to inspect the toothed side of the belt at the joins where the teeth rise out of the backing belt.
The first symptom of imminent failure will not be the condition of the belt but the presence of tiny cracks in the joins of the teeth to the belt. By joins I mean where the moulded teeth rise up from the backing belt. That is the weak spot.
