I would like to add three point seat belts to my 65 TI. I think I read that 67's and onward have an attachment point up the b-pillar, but I can't seem to find one on my 65. Anyone dealt with this?
Weird. My '63 1600 Ti was a CKD car put together in South Africa. It has (and they are original), correct mounting points for 3 point belts in the pillar.Yes actually. My 65 Super came with no B-pillar hole/mounting point. A PO put one in (on both sides) and 3-point belts. How I do not now. But . . .
thanks Bruce!So the '72 that was factory installed, from C/L of bolt to:
- level of top of stainless steel window/door trim is 6 1/2"
- level of white b-pillar fabric to brown vinyl trim is 8 1/4"
The white '65 that had NO factory 3rd point installed but was drilled per above, from C/L of bolt to:
- level of top of stainless steel window/door trim is 8 1/2"
- level of white b-pillar fabric to brown vinyl trim is 10 1/4" Both here a difference of 2" higher.
Both seem comfortable to me at 6'2" I had never noticed the difference. You want it as low as you can get for comfort so your head does not slip out in a crash if the door opens. The lower position may be better for passengers who are not as tall as you typically. While it seems like the factory setting is lower by 2", I don't think 2" would make a huge difference.
PS: fishing the nut down with thread through the light assembly opening (disconnect battery) is not easy and requires a lot of tries, patience and luck and cussing. If anybody knows a better method, I'm all ears. I would not trust taping and threading the B-pillar metal as it is not too thick and would pull out. A second person would help to hold the belt assembly tension up while youi fish with the bolt through the hoiunting tang hole, the B-pillar hole and to the waiting aligned nut. Good luck.
