CatCam issues V6 12V
From an Alfa owner that had his car modified in Europe.
His issues are not atypical unfortunately.
Engine is 3.0 V6, 11 to 1 pistons, individual throttle bodies.
Complaint was
extremely noisey engine. No power below 5000 RPM.
Cams:12mm Catcam
camshaft details | CAT CAMS performance camshafts
In a message dated 12/22/2014 6:27:04 P.M. Central Standard Time,
xxxxxxx@msn.com writes:
Hi Richard,
Nice speaking with you today. Thank you for your words of wisdom.
I will try to measure the intake runner length as soon as I can.
Let me know when you would like me to send the stock Verde camshafts, and can you please provide your address again.
Best,
xxxxxx
In a message dated 12/27/2014 5:49:22 P.M. Central Standard Time,
deriko@msn.com writes:
AlfaR7@aol.com
Date: Tue, 23 Dec 2014 08:10:31 -0500
Subject: Re: Camshaft Inquiry
To:
xxxxxx@msn.com
While you have the cam cover off check the lash on one intake and exh. That needed to be known as well. If exh lash is over .008 they are easy to tighten up. Intake should be .012 - .014(max) they require removing to change shims.
The cam selection really is a matter of what "real" clearances exist for lobes using a realistic base circle.
The 429 is a proven lower lift lobe design. The exh lobes for the V6 are on pg. 17 The 82 is my "race" exh. You can see it has far less early duration but more "open valve" duration than the CatCam. You have no torque due to excessive overlap due to too much early "off the seat" lift duration on intake and exhaust cams, incorrect tight lobe separation angle (106/106) and just too much exhaust lobe ffor the engine design.
For an exh lobe I would suggest probably the RjR61 or 61+3(6). If we used the RjR82 exh I would change the LCs to 110 int / 112 exh to keep torque high.
In a message dated 12/23/2014 1:58:51 A.M. Central Standard Time,
Didn't know if you still needed it, below is the part # and spec sheet on my cams.
http://www.catcams.co.uk/acatalog/1030322.pdf
I'll pull off the covers tomorrow to get the pictures you requested.
So you think the RjR429 would be a good choice for me?
Best,
xxxxx xxxxxx
Sent from my iPad
On Dec 22, 2014, at 6:02 PM,
AlfaR7@aol.com wrote:
I found your cams on the CatCam website so I don`t need that info. When you look at duration the RjR429 is probably more intake cam than you are currently using, just less lift. (at .040 260 deg compared to CC`s252)
Their (CatCam`s) 11.5mm lift cam set shows 110-110 Lobe centers. Too bad they didn`t use that on this cam set.
Lash per their specs should be .008 exh and .014 intake. I bet lash has been set to Alfa specs (.020 int and .009 exh.) Rocker lash should be .008 at the cam follower not under the rocker, (Typically the settings for such intake cams would be .012-.014)
Attached you will find a PDF file with the cam profiles.
You should measure the base circles of the existing cams, both an intake lobe`s and an exhaust lobe.
A picture of the engine might help, as well as a picture of the cams from several angles with the cam cover off. This way I can see any modifications for cam lift at the cam bores.
With your engine upgrades you should be making well over 300 HP. Have you had the motor Dynoed?
You should to establish a baseline map.
Also please scan the cams data sheet and email to me. I need to see what I can determine from the little info given buy the builders in Europe.
Is there a part #?
See the RjR429 intake. That is a 11.2mm lift cam that when compared to the stock Verde (same as all 2.5V6s) or the "S" cam will show this to be basically a high torque/HP intake with more later duration than most early race cams. Difference is the new cam designs make good low end power, not just at high rpms.
Rj
Hi Richard,
Hope you had a good holiday.
Was able to take the cam covers off today. My best measurement of the base circle was 25.40mm, the runner lengths are approximately 4 3/4".
Can you tell me which cylinder(s) lash measurement you want. Engine is currently at TDC. The exhaust valves on #1,2,4, and 6 have probably 1/8" of clearance between the cam and end of the lifter/rod. Don't know if it's supposed to be that wide open..? Seems weird to me.
Can send my Verde cores anytime, need your address please.
Here are a few pics, let me know of you need more.
Best,
xxxxx xxxxxx
xxxxx:
Re: Pics
You do have serious issues. The cams are by lobe shape (even with no other info), old school race cam designs. (high overlap, no power except at high RPMs.
Re: Measured data:
It appears that the cams are very small Base Circle cams as well (1.000 inch) (25.4mm ) or less in order to fit your unmodified head. However I can`t imagine the cams not having clearance issues in the "seal to keeper distance" as valves open. I will not build cams with Base Circles this small unless demanded and then under protest, nor use 12mm in a head that has not been extensively modified including deeper spring pockets and approiate short guides and correct spring design for both intake and exhaust (they are different). Obviously these were not designed by anyone knowledgable of these V6 12V engines.
The clearance you gave (appx 1/8 inch) on the exhaust is a real problem. They must not have changed or done any valve adjustment. Be sure the cam followers are not showing any wear. If so they cannot be used, particularly on new cams!
As I mentioned in an earlier email, the Exhaust lash is measured at the interface between the heel (base circle center point) of the cam lobes, and the cam follower, should be .008, and NO larger. However, these very small base circles would be best set at .006. (and lets use inch measurements from now on as it`s the US standard., and the way I specify clearances)
If it is more unlock the adjustment screws and close the lash to .006. (I hope you have room to do this with such small base circles!)
There is a solution to dealing with lifter clearances on small base circle cams. You put a intake type adjusting shim on top of the exh valve and then set lash. The shim should have a minimum thickness if .080 to take the stresses of the ball end of the adjustment/lifting screw.
On the intake side measure clearances with a feeler gauge set between the heel of the cam lobe and the cam follower. The "CatCam" specification was .014, however with such small base circles as in this set, they should be no more than .010. I suspect again that these cams were "built on order" from someone trying to get more lift without correct internal modifications in the head!)
FYI: you will have to turn the motor over by hand to get exh lobes in position to reset lash. While turning it to do that you will have the opportunity to measure intake lash during that process as the intake cam lobe`s heels are in the correct position as you move the motor.
If the intake lash is over .014 you will have to pull the cams and using the correct shim, close intake lash to .010.
Let me know what you find lash wise on all of them! IF when you reset lash and when turning the engine over by hand you feel heavy resistance, that would be lack of clearance beween the seals on the guides, and the keepers in the spring retainer. Do not continue to turn the motor as you will destroy the seals.
Do not run it as it is either!
My address is below, however send the Cams to my West Coast Wife!
Send Cams to:
XXXXXXXXXXXXXX
xxxxxxxxxxxxxxxx
xxxxxxxxxx xx
xxxxx
My address:
Richard Jemison
xxxxxxxxxxxxxx
Pensacola, Fl.
32514
