Speedometer To Work
Now i do not know if this would work but i found this website on another thread
www.dakotadigital.com here is what they offer:
Universal Speedometer Signal Interface
From Dakota Digital
The SGI-5 Universal Signal Interface Unit can handle all of your electric speedometer signal conversion and calibration problems. The SGI-5 can recalibrate 8K pulse per mile (ppm) through 250K ppm electronic speedometer pulse rates. The SGI-5 is great for readjusting aftermarket and OEM electric speedometers on vehicles after changing rear end gears.
The SGI-5 can also handle all of your speedometer pulse rate incompatibility problems. Does your VDO Hall Effect Speedometer generator produces a 16K ppm and your cruise control requires a 2K, 4K or 8K ppm? No Problem!
Does your older GM 700R4 transmission produce 4K ppm and your new cruise control require a 8K ppm? No Problem!
The SGI-5 can also assist in creating tach signals for diesel engines when combined with a flywheel gear-tooth sensor or purchased as a kit the DSL-2 Universal Diesel Flywheel Tachometer Interface.
Would this make the GTV6 speedometer work using the Milano transmission.
Any help thanks Sebastian
