Work has slowed on the bodywork so I decided to remove the cylinder head and do some some refurbishment. Background: I'd run the engine on my newly aquired 62 Sprint several times and regular as clockwork after 10 minutes it would produce clouds of grey/white smoke much to the annoyance of the neighbours. On checking compressions I found two cyls at 160 psi and two at 130 psi. Not bad for an old motor. Oil pressure was always good and engine was mechanically quiet. So I thought it would be worth taking a look at the valves and changing the head gasket. First thing I found was the chain link installed the wrong way around. I'm now thinking this does not bode well for previous work undertaken.
Unfortunately I've now got the head stuck by some careless final lifting.
I'd already made the usual tool to fit the plug holes and it worked really well. I had to move it between cyls and use various lengths of M10 bolts (as spacers) to effectively jack the head up high. At this point I started to lift it and one end and it suddenly came right off the studs leaving the other end still engaged by about 20mm with the head now lying at a stupid angle. So my next step is either to hire an engine hoist or try some wood tapered wedges. Anyone got any ideas?
