The top is in the final stages of finish work. I punched a hole where the T-bolt is to go and installed a 4mm bolt with washers on both sides of the fabric and put that through the hole in the frame, then secured it with a nut. I am going to have to work on alignment for the end as there seems to be a gap as it hangs down to low. The cables I just made tight and that seems to be sufficient.
I ordered a new rubber for the top front bow. In trying to install the rubber in the channel with liberal amounts of Sil-Glyde, I gave up in frustration after only being able to get about 6 inches into the channel. My thought was the channel was to rusted to move the rubber through, so I ordered a new channel. My next thought was to install the rubber in the channel before installing it on the top and then shifting the rubber back and forth to pop rivet the part to the top.
Well, I got to looking at the rubber part I had and figured out that the width of the base that slides in the channel is about a .5 mm to wide. Hence, the rubber binds going into the channel and therefore you can only get about a foot maximum before it binds all together. I tried silcone spray, 303, sil-glyde, white grease and liberal amounts of elbow grease to get the new rubber to go into the new channel.
As I was mulling how to either shave a hairs width off the sides of the rubber, it was then I remembered I got a peice of odd looking rubber with the car in all the parts. I fished for it and turns out to be a different type of rubber than the one I just bought, but it a top rubber seal. So, I lubed up the rubber and it slid right into the channel with alot less effort, albeit it still was hard getting it to move.
The replacement rubber is to wide. Putting my metric calipers to the base the old rubber was 16.9mm wide. The new rubber I just bought was 17.9mm. Ah, I was close, it is .5mm wider on each side, hence it won't slide in the channel, no matter how much grease I put on it. The inside of the channel as best I can measure is 18.7mm. The difference between the new rubber and channel is .5mm (or .25mm on each side) making a very tight fit. The difference in the old rubber and the new channel is 1.5mm (.75mm each side) thereby making it easier to pull through.
Lets say it has been an interesting afternoon.
Now to install the top rubber tomorrow and finish off this top.
Wife says it looks beautiful.
