821 - 840 of 854 Posts
Discussion starter · #824 · (Edited)
Stainless tips for tailpipe 2.25'' and 2'' diameter, straight & slant cut
"NEW" center to rear section exhaust donuts "NEW"
Exhaust manifold for 1600-1750-2000 engines for cylinder 2 & 3 only
Throttle linkage rods 4''
2 - 1750/2000 GTV & Smooth nose GTJ radiators
Golden Lodge pink HL & 2HL plugs and white 2HL plugs
Magneti Marelli pink CW260L spark plugs
Bosch distributors & rotors & caps
Hood & trunk release components
GT hood, smooth nose
Passenger door from S1 1750 GTV or earlier GT with window mechanism
Aluminum front spring spacers 3, 6, 7 & 10mm
Front lower A-arms, upper arm, castor arm, steering arms, and rods...
"NEW" castor arm "NEW"
Rear trailing arms
T bar, and conical bushings
OE Spica shock absorbers, 4 front, 2 rear
Front anti-sway bar,
2 pairs front springs
Rear anti-sway bar for Spider
Rear shortened Berlina springs
stock rear springs
Door handles exterior & interior, window winders & pivots, door hinges...
Jaeger Italia fuel, and temp (degrees F) gauges for 1750 GTV
Veglia Speedo MPH, Jaeger Tach and (psi) oil pressure unit for 1750 GTV
Veglia fuel gauge for unknown Italian car
C pillar badges for 1750 & 2000 GTV
GT chrome and stainless parts
Rear bumper side extensions for Series 1 1750 GTV and older GTs & GTJs
Rear stainless steel bumper for Series 2 1750 GTV and newer GTs & GTJs
Front parking light S2 Euro 1750 GTV
Rear tail lights and lenses small GT Euro 1750
Glass for side and rear windows on GT
1 rear screen no defroster wires
5 side rear vent glass
4 front door vent glass 2x CT, 2x SICURSIV
1 front vent glass
"NEW" Engine gaskets and seals "NEW"
Fispa mechanical fuel pumps # 4033.01, # 4008.09 and # 4044.01
Malpassi Filter King fuel filter/pressure regulator glass bowl for 105 Alfa
Spica parts, rear fuel pump bracket, fuel line brackets
Spica & Euro front engine covers 1750
Water pumps for early alternator Alfas, 2 outlet hose fittings 68-72
Rad overflow caps, and clamps
1750, 1600, 1300 steel wheels 14''x 5.5'' 38mm offset w hubcap bumps
Cam Cover for 1968-1977, Olio fill cap
Camshaft 105200320000 9.6mm lift
Camshaft 105020320001
Cam follower buckets and keepers
Valve shims
Connecting Rods, Oil Filters and canisters
Clutch master cylinders hanging pedal
Brake Master cylinders, floor mount dual circuit internals,
and hanging pedals
RIBE bolts & nuts for front calipers
Floor pedals and pivot arm
"NEW" right rear Ate caliper "NEW"
Used brake pads for 105 cars
Brake booster diaphragm floor pedal Euro Alfa
front RHT & LHT wheel studs
GTV 1750 S2 rear seat vinyl, series 2, black fair condition
1750 engine, block, crank, oil pans, and S2 head
transmissions, and transmission parts
Starters and Solenoids and Alternators
Thackeray washers & O rings for solid intake
Interior mirror parts
Washer Bag Cap and parts
Hand brake levers, handles, and parts
Interior lights and trim parts
Vintage Carello twin wire wiper blades, wiper arms
"NEW" 1750 GTV S2 grill heart with badge "NEW"
I have a 4.56 open axle. I want to trade it for a 4.10 open axle.
brochure for 1750 Berlina
sales brochure for GTV-6
sales brochure for Giulia Sprint GT
sales brochures for Giulia Spider
sales brochure for Sprint 1300
1750 round tail Duetto road test Track & Traffic Magazine
68 GTV road test Track & Traffic magazine
many Alfa books & workshop manuals
I have many more parts not listed.
Discussion starter · #829 ·
Anyone have a good complete working 4.10 rear axle from a 105 Alfa? Open diff is ok vs LSD. Willing to trade a good working complete 4.56 open axle or other parts or cash.
Hi Brad,
Do you still have:
Spica water pump for US spec Alfas "hard to find now"
Do you have:
The rubber skirts that cover the sides and package tray behind the front seats (71 Spider)
Also, I just noticed that I’m missing the rubber "plug" that slides onto/into the channel at the top of the wing window rail for my 71 Spider, I.e., at the top of the channel that the window rides up/down in. Have one?
Best,
Bob
@brad fischer - I need the box part of a 71-74 GTV glovebox. As pictured below and red arrowed. Have one?
Discussion starter · #838 ·
A few treasures unearthed and cleaned up.
Discussion starter · #840 ·
The brass coloured metal and spring go together as shown in some of the other photos. I took it apart to clean it. It fits inside the bypass hose shown. It is used on Spica injected Alfas to speed up engine warming. There are some threads on this on ABB. I think it is a rare part that often got thrown away when changing rad hoses, so not many around these days.
