801 - 820 of 854 Posts
Discussion starter · #802 · (Edited)
Small left tail light Carello lenses for GT. The rectangular Carello reflector that fits in the lens is available as well.
Discussion starter · #803 ·
Speaker covers for console 1750/2000 GTV/Berlina/Super. The original plastic pair are the same screw hole spacing as the metal pair.
Discussion starter · #805 ·
The original plastic pair on the right of the first photo. The metal pair are identical in screw hole size and spacing. The Sony pair are added in the photos for fun. I didn't notice any cracks when i cleaned them.
Discussion starter · #806 ·
105/115 window winders. Original, very clean. Vent winder is 26mm thick main winder includes grub screw.
Discussion starter · #809 · (Edited)
I want to sell some Alfa parts that I probably won't need. I will try to provide a partial list, ADD to it as required, and supply photos if requested. I will UPDATE this list regularly. I still have parts from a 67 GT Junior that I parted out years ago, plus very few Spider & Berlina parts and lots of GTV parts, mostly from 1750 GTVs. Some 1600 GTV & 2000 GTV parts. Here is a partial list of some "NEW" and mostly used parts.
Stainless tips for tailpipe 2.25'' and 2'' diameter
"NEW" center to rear section exhaust donuts "NEW"
Exhaust manifold for 1600-1750-2000 engines for cylinder 2 & 3 only
Throttle linkage rods 4''
2 - 1750/2000 GTV & Smooth nose GTJ radiators
Bosch distributors & rotors & caps
Hood & trunk release components
GT hood, smooth nose
Passenger door from S1 1750 GTV or earlier GT or GTJ
Aluminum front spring spacers 3, 7 & 10mm
Front lower A-arms, upper arm, castor arm, steering arms, and rods....
Rear trailing arms, rear springs shortened Berlina
T bar, and conical bushings
OE Spica shock absorbers, 2 front
Front anti-sway bar, front springs
Rear anti-sway bar for Spider
Door handles exterior & interior, window winders & pivots, door hinges...
Jaeger Italia fuel, and temp (degrees F) gauges for 1750 GTV
Jaeger Tach and (psi) oil pressure unit for 1750GTV
Veglia Speedo MPH
Veglia fuel gauge
C pillar badges for 1750 & 2000 GTV
GT chrome and stainless parts
Rear bumper side extensions for S1 1750 GTV and older GTs & GTJs
Rear stainless bumper for S2 1750 GTV and newer GTJs
Front parking light S2 Euro 1750 GTV
Rear tail lights and lenses small GT Euro
Glass for side and rear windows on GT
1 rear screen no defroster wires
5 side rear vent glass
2 front door vent glass
"NEW" Engine gaskets and seals "NEW"
Fispa mechanical fuel pumps # 4033.01, # 4008.09 and #4044.01
Spica parts, rear fuel pump bracket, fuel line brackets
Spica & Euro front engine covers 1750
Aluminum wheel spacers 2 of each size, 6.35mm, 4.76mm
Water pumps for early alternator Alfas, 2 outlet hose fittings 68-72
Water pump for 1300 & 1600 cars 101 or 105 with generator 2 outlet
Spica water pump for US spec Alfas "hard to find now"
Rad overflow caps, and clamps
1750, 1600, 1300 steel wheels 14''x 5.5'' 38mm offset w hubcap bumps
Cam Cover for 1968-1977
Camshafts, connecting Rods, Oil Filters
Clutch master cylinders hanging pedal
Brake Master cylinders, floor mount dual circuit internals, and hanging pedals
Floor pedals and pivot arm
"NEW" right rear Ate caliper "NEW"
"NEW" rear brake pads "NEW"
Used brake pads for 105 cars
Brake booster diaphragm floor pedal Alfa
front RHT wheel studs
GTV 1750 rear seat vinyl, series 2, black fair condition
1750 engines, blocks, cranks, oil pans, front cover and heads
block heater 400 Watt 120 Volt
transmissions, and transmission parts
Starters and Solenoids
Interior mirror parts
Washer Bag Cap and parts
Hand brake levers, handles, and parts
Interior lights and trim parts
brochure 1965 Sprint GT, Giulia 1600 Spider & Veloce, TI, SS, TZ, 2600 Sprint & Spider
sales brochure for 1750 Berlina
sales brochure for GTV-6
sales brochure for Giulia Sprint GT
sales brochures for Giulia Spider
sales brochure for Sprint 1300
sales brochure for 1992 Spider & 164
many multi-page promotional materials
1750 round tail Duetto road test Track & Traffic Magazine
80s Spider brochure
68 GTV road test Track & Traffic magazine
many Alfa books & workshop manuals
I have many more parts not listed.
Discussion starter · #818 · (Edited)
Golden Lodge pink HL & 2HL plugs and white 2HL plugs
Magneti Marelli pink CW260L spark plugs
Aluminum front spring spacers 4, 7 & 10mm
Rear trailing arms
Rear shortened Berlina springs
Veglia Speedo MPH, Jaeger Tach and (psi) oil pressure unit for 1750GTV
Veglia fuel gauge for unknown Italian car
Rear bumper side extensions for Series 1 1750 GTV and older GTs & GTJs
Rear stainless steel bumper for Series 2 1750 GTV and newer GTs & GTJs
Rear tail lights and lenses small GT Euro 1750, 1600 & Jr
4 front door vent glass 2x CT, 2x SICURSIV
Fispa mechanical fuel pumps # 4033.01, # 4008.09 and # 4044.01
Malpassi Filter King fuel filter/pressure regulator glass bowl for 105 Alfa
Spica water pump for US injected Alfas "rare part now"
Cam Cover for 1968-1977, Olio fill cap
Camshafts 2 sets 105200320000 9.6mm lift
Camshafts 105200320001
Cam follower buckets and keepers
Connecting Rods, Oil Filters and canisters
and hanging pedals
used brake pads for 105 cars
brake booster diaphragm floor pedal Euro Alfa
front RHT & LHT wheel studs
1750 engines, blocks, cranks, oil pans, and heads
vintage Carello twin wire wiper blades, wiper arms
"NEW" 1750 GTV S2 grill heart with badge "NEW"
80s Spider brochure
Discussion starter · #819 ·
Two 551 engines for USA 1750.
Discussion starter · #820 ·
Three transmissions, two set up for 10/41 rear.
