Greetings;
I want to sell some Alfa parts that I probably won't need. I will try to provide a partial list, ADD to it as required, and supply photos if requested. I will UPDATE this list regularly. I still have parts from a 67 GT Junior that I parted out years ago, plus very few Spider & Berlina parts and lots of GTV parts, mostly from 1750 GTVs. Some 1600 GTV & 2000 GTV parts. Here is a partial list of some "NEW" and mostly used parts.
Stainless tips for tailpipe 2.25'' and 2'' dia,
Rear section exhaust for GTV
"NEW" center to rear section exhaust donuts "NEW"
Exhaust manifold for 1600-1750-2000 engines for cyl 2 & 3 only
Throttle linkage rods 4''
2 - 1750/2000 GTV & Smooth nose GTJr. radiators
Bosch distributors & rotors & caps
Marelli distributor & rotor & cap
Hood & trunk release components
GT hood, smooth nose
Passenger door from S1 1750 GTV or earlier GT or GTJr.
Aluminum front spring spacers 7 & 10mm
Front lower A-arms, upper arm, castor arm, steering arms, and rods
Rear trailing arms
T bar, and conical bushings
OE Spica shock absorbers, 2 front, 1 rear
Front anti-sway bar, front springs
Rear anti-sway bar for Spider
Rear parcel shelf 1969 and older GT
Interior rear side panels 1969 GT and older, excellent black vinyl
Door handles exterior & interior, window winders, door hinges, etc...
Jaeger Italia fuel, and temp (degrees F) gauges for 1750 GTV
Veglia Borletti Speedo MPH, Jaeger Tach and (psi) oil pressure unit for 1750GTV
Veglia fuel gauge
C pillar badges for 1750 & 2000 GTV
GT chrome and stainless parts
Rear stainless bumper side extensions for Series 1 1750 GTV and older GTs & GTJrs.
Rear stainless steel bumper for Series 2 1750 GTV and newer GTs & GTJrs.
Front parking light S2 Euro 1750 GTV
Rear tail lights and lenses small GT Euro and USA 1750 S1
Glass for side and rear windows on GT
1 rear screen no defroster wires
5 side rear vent glass
2 front door vent glass
"NEW" Engine gaskets and seals "NEW"
Fispa mechanical fuel pumps # 4033.01, # 4008.09 and #4044.01
Spica parts, rear fuel pump bracket, fuel line brackets
Spica & Euro front engine covers 1750
Aluminum wheel spacers 2 of each size, 6.35mm, 4.76mm
Water pumps for early alternator Alfas, 2 outlet hose fittings 68-72
Water pump for 1300 & 1600 cars 101 or 105 with generator 2 outlet
Rad overflow plastic bottle, and caps, and clamps
1750, 1600, 1300 steel wheels 14''x 5.5'' 38mm offset w hubcap bumps
Cam Cover for 1968-1977
Camshafts, Liners, Pistons, Rods, Oil Filters
Clutch master cylinders hanging pedal
Brake Master cylinders, floor mount dual circuit internals, and hanging pedals
Floor pedals and pivot arm
"NEW" rear brake pads "NEW"
Used brake pads for 105 cars
Brake Calipers front & rear 1750/2000
Brake booster diaphragm floor pedal Alfa
GTV 1750 rear seat vinyl, series 2, black fair condition
GTV 1750 front seat, Flying Buttress type, Series 1, Euro, drivers no headrest type, LHD
1750 engines, blocks, cranks, oil pans, and heads
block heater 400 Watt 120 Volt
transmissions, and transmission parts
Starters and Solenoids
Interior mirror parts
Washer Bag Cap and parts
Hand brake levers, handles, and parts, cables, and shoes.
Interior lights and trim parts
brochure 1965 Sprint GT, Giulia 1600 Spider & Veloce, TI, SS, TZ, 2600 Sprint & Spider
sales brochure for 1750 Berlina
sales brochure for GTV-6
sales brochure for Giulia Sprint GT
sales brochures for Giulia Spider
sales brochure for Sprint 1300
sales brochure for 1992 Spider & 164
many multi-page promotional materials
1750 round tail Duetto road test Track & Traffic Magazine
80s Spider brochure
68 GTV road test Track & Traffic magazine
many Alfa books & workshop manuals
I have many more parts not listed.
Rear trailing arms
Veglia fuel gauge
80s Spider brochure
