1600 Head Advice Needed
3.6K views 14 replies 9 participants last post by  Stachowiak
#1 · (Edited)
I have a 1600 head that i want to use on the Duetto. It measures a full 112mm thickness, but there are a few marks on the mating surface. It is the original head that came with the motor. At least it was on the block when I got it. I'm assuming from my thickness measurements that the head has never been shaved, and I intend to take it to a shop for evaluation. Were these heads like this from the factory? I'd hate to cut 112mm head just for cosmetics I will never see again. . Does it look usable as is? What do the BB experts think? The problem cylinders are #1 and #3
#2 ·
Head
It is going to take a hefty cut to get to a smooth surface to make the head usable.
Shaving the head is a good thing compression wise. .050 to .060 is commonly done with stock pistons. With 9.0 to 1 stock pistons you will end up just under 10.5 which is perfect for 92 octane fuel.
#3 ·
Though once you cut it, you can never un-cut it. You can also increase CR if you're so inclined by cutting the head the minimum needed, and using pistons with a bigger dome, though that has its own issues in how combustion happens, and in valve/piston and head/piston clearance, which the engine builder will need to check. My preference is to cut as little as possible; they aren't making new ones.
There is more than one way to go, of course. What use are you intending?
#8 ·
Head thickness
There`s a lot of material available to be removed. .050 - .060 is not a lot. Commonly these old heads are cut .070+ to get compression.
In the early `70s I cut the head ,050, then decked the block, front cover and liners .040 to get the original 1600 in the Duetto up to 12 to one with lightened stock 9.0 pistons. Worked great, no big dome to deal with and better squish and flane travel.
Stock head is 4.410" so less .060 would be 4.350''.
#15 ·
Tom,
The best place I know for that work is in Cortland NY. They do lots of Alfa work and they did my head work a few years ago. I think the name of the place is Precision Automotive. I'll get back to you with the contact info when I get back to Syracuse.
Dick
