SD709 and SD7H15 Sanden Compressor Parts Info
15K views 17 replies 5 participants last post by  Alfisto Steve
#1 · (Edited)
I ordered some repair parts and tools today so I can install some new shaft seals in a couple compressors I have. My supplier is Harolds Electric Co (HECO). Harold Electric Co. specializing in Ag & Mobile Products
Another vendor's number MT2045F SANDEN SD7H15 SHAFT SEAL KIT, Max-AC - Automotive Air Conditioning, AC Parts Tools Equipment Kits
Another vendor number SS-0846-R134a Polar Bear in Ft. Lauderdale, FL
Polar Bear, Inc._product_ShaftSeals6
1. SD7H15 shaft seal is about $20 from my supplier HECO out in Walla Walla, WA. His part number is 52554.
2. SD-709 shaft seal is about $16. His number is 52553.
Another vendor number SS-0830-R134a Polar Bear in Ft. Lauderdale, FL
HECO carries removal and installation tools, too which is why I like to deal with them.
I already had most of the SD-709 shaft seal tools so now I ordered the ones for SDH715 compressor which I didn't have.
One I get them and verify they are correct tools I will post more info.
#6 · (Edited)
Working on seal change on SD-709 Sanden Compressor
I started on seal replacement on Joe's compressor after my 164B left the building today.
I was able to remove clutch plate only to find no snap ring to hold pulley and bearing to compressor but being a pressed fit it was still below groove where snap ring should have been. Once I pulled pulley off and removed coil I found felt wiper shown in picture was missing. So missing snap ring and missing felt tells me somebody has been in here before.
The pulley bearing seems like new but the orings in the inner and outer portions of shaft seal and under the drain plug still the black ones found in the orignal R12 compressors. You can see green R134a oring seals in new shaft seal set.
This may have been a remanufactured compressor he put in many years ago.
I am down to my last new shaft seal assembly from Harold Electric.
I may not get back to project until Monday now. Wife got back from beach house so we went out to dinner. I have F1 breakfast in the morning and then helping serve fellowship lunch at church; etc... with the wife tomorrow.
Also found out Polar Bear sent me on my last order sometime ago a spare CB-3052C 30x55x23mm bearing for a Ford instead of correct 35x55x20mm CB-9703 for Alfa and Chrysler. Even though Joe's bearing seems like new I think I need to install a new one.
I guess I should have added spare bearing to list of stuff I ordered from Harolds Electric Co.
#7 ·
Now how did she know to do that?
Just got this email in with bearing list in xls spreadsheet. See what searching for bearings on internet does somebody watching my key strokes it seems. Pretty Scary!
This is Alice Xia from ABE Bearing Co., Ltd. of Hongkong.
How are you ?Hope everything is well.
Besides our own brand"ABE",We stock lots of SKF FAG INA TIMKEN NSK NTN KOYO NACHI BRAND BEARINGS.
If you interested anything,free samples and pictures will be available.
Your any reply will be highly appreciated.Thanks
Sincerely yours
Alice Xia
Web:ABE bearings Co.,Ltd. of Hongkong
MSN: abebearing@hotmail.com
Skype:abebearing
TEL: 00852 30758520
FAX: 00852 31828521
Email: sales@abebearing.com
#8 · (Edited)
Ordering bearings online for A/C pulley and serpentine pulley, etc...
Yesterday I did a little e-commerce with amazon.com and ordered up some new spare bearings for A/C clutch pulleys, serpentine belt pulleys and cooling fan motor armatures.
Some choices I found on Amazon 35x55x20mm size bearing
AC Compressor Clutch Bearing KOYO 83A894 or 35552RD3XS1CS33-F for Sanden SD-709/SD7H15 (also fits my Dodge Ram PU compressor).
Replacement for NSK 35BD219DUM A/C $22 (not sure what part number will be of this one but ordered one to see anyway).
AC Compressor OEM Clutch Bearing NSK 35BD219DUM A/C $25 on amazon
Amazon.com: AC Compressor OEM Clutch Bearing NSK 35BD219DUM A/C: Automotive
ACDelco 15-2802 A/C Compressor Pulley Bearing $18.81 Can't confirm this bearing size as measurment data on amzon does not compute/convert to 35x55x20mm.
Cooling fan motor bearings:
SKF 6200 2RSJEM Light Series Deep Groove Ball Bearing, Deep Groove Design, ABEC 1 Precision, Double Sealed, Contact, Steel Cage, C3 Clearance, 10mm Bore, 30mm OD, 9mm Width $10.81
164 12v Serpentine belt pulley bearing:
SKF 63004-2RS1 Radial Bearing, Single Row, Deep Groove Design, ABEC 1 Precision, Double Sealed, Contact, Normal Clearance, Steel Cage, Metric, 20mm Bore, 42mm OD, 16mm Width $26.28
#9 ·
Some choices I found on Amazon:
AC Compressor OEM Clutch Bearing NSK 35BD219DUM A/C $38.75
Also this option:
35BG05S16G-2DL NACHI Double-row Auto Air Conditioning Angular Contact
Had good luck with NACHI in the past though a bit lesser known than KOYO or NSK.
#11 · (Edited)
Pressure and vacumn testing Alfa 164 Sanden Compressor
Sanden seal installer tools arrived today.
I got in the shaft seal installers for both the Sanden SD-709/SD508 shorty and SD7H15 compressors today.
What a difference using 90907 seal protector/installer bullet made to slip new shaft seal onto Joe's SD-709 compressor,
I will try out the smaller 91075 bullet for the SD7H15 compressor next.
I pressure tested compressor to 100 psi with R134a freon after installing 4 oz of ester oil and then pulled 30 in HG to and it passed both tests.
I will post pix of using installation tools later on next compressor I do.
#12 · (Edited)
Earlier this afternoon I had a good conversation with Joe from PolarBear INC.
I have a Sanden SD709 there and not sure whether he is rebuilding that or providing a new SD7H15 with my pulley.
Either way he installed new pulley bearing and indicated cost around $289.00.
Another great Alfa day here in NE FL.
Ta,
Neville.
#13 ·
1. Interesting set up for testing the compressor. Are the fittings put together from a hardware store? I'd like to test a couple of my 4 spare compressors.
2. I recognized that red Bricklin on your tool box right off. I was working in St John NB, Canada when the St John factory was setup and started producing them:)
#14 · (Edited)
My Sanden Compressor test fittings
Only thing from hardware store (Home Depot) is two 5/8" brass caps on silver compressor fittings. One fitting has R134a Low pressure side service fitting with valve core and other one has R-12 service fitting with valve core.
I have no idea where I got them from or when I got them but they sure do fit the CB head on Sanden compressors just like Alfa 164 hoses do.
I think these are the Harold Electric Co part numbers for the fittings but my flare nut caps from HD were 5/8"
R-134A ROTOLOCK SERVICE VALVES
451-220R # 8 Hose-3/4” Male Flare Thread
451-231R # 10 Hose-7/8” Male Flare Thread
ThreadR-12 ROTOLOCK SERVICE VALVES
451-220 # 8 Hose-3/4” Male Flare Thread
451-231 # 10 Hose-7/8” Male Flare Thread
#15 ·
where can we find / buy
new CB heads, and head gaskets for the CB head. I was told long ago that the head gaskets come in variable thicknesses to accomodate mfg tolerances. I will go back and look to see if I can find the description == although I do not think the service manual mentions this--
#16 · (Edited)
http://www.heco.net/MainCat/Main_Cat.htm
Harold Electric
811 W. Rose, Walla Walla, WA 99362
Phone: (509)525-5070 Fax: (509)525-3753 1-800-541-8910
Harold Electric Co. specializing in Ag & Mobile Products | E-mail: heco@bmi.netCompressor
Harold Ag and Mobile Products Main Parts Catalog
http://www.heco.net/MainCat/Compressors.pdf for CB head and head gasket and shaft seals
CB Head Vertical Tube O-Ring, 1" x 14 W/O Charging Ports fits SD708, SD709, SD7H13, SD7H15 HECO.net part # CH-5000
GA-1336 Sanden SD505, 507, 508, 510 Cylinder Head Gasket
GA-1342 Sanden SD708, 709 Cylinder Head Gasket
GA-4466-KT Rubber Coated Metal Gasket Kit SD505, 507, 508, 510, 5H14
GA-4488-KT Rubber Coated Metal Gasket Kit SD7H15
52553 shaft seal Fits Sanden SD708, SD709
52554 shaft Lip Seal fits Sanden SD5H, SD7H series
http://www.heco.net/MainCat/AC_Tools.pdf for tools to remove and install shaft seals.
Bob I have a used CB head and just ordered a GA-4488-KT head gasket set to go with it. Also ordered GA-4466-KT gaskets for installing CB head on SD-709 compressor. Slight difference in gasket sets it seems.
HECO.net parts guy said they have new CB head and the parts guy said it comes with gasket set for $35 if you want to order it from them.
They sent me wrong shaft lip seals for the SD7H15 so I had to reorder correct 52554 seals I ordered last week. Invoice had correct part number I ordered but they sent me 52552 seals for SD-508 instead.
Pix show CB head and head gaskets with 7-cylinder reed valve plate that goes between head gasket set.
#18 ·
Do you have the 90907 black thin walled bullet that fits over the crankshaft for installing shaft/lip seals on both SD-709 and SD7H15 compressors?
That was the one tool I did not have and I could not install seal on SD7H15 without damaging seal.
