Okay, so I pulled off the PS wheel and wheel liners and found no loose or missing parts in the timing belt/accessory belt area. Nothing at all.
What I did next was compression tested all six cylinders and got 180 across the board which I was suprised because the car uses oil and spark plugs had crud on them. Anyway, when plugs were removed, I stuck a magnet down the spark plug holes and felt around and nothing moved or came back up with it.
So, no missing or loose parts, compression was fine provided I did it the right way, which meant there was no damage to valves, and there were no objects obstructing the belts...I just don't understand. Maybe the engine is bumping the frame? Or maybe when I put a piece of wood under the oil pan, it still bent causing friction with the crankshaft?
I made a short video clip of what it sounds like when I start it up. The sound is a lot louder than what you can hear.
<embed width="430" height="389" type="application/x-shockwave-flash" wmode="transparent" src="http://smg.photobucket.com/player.swf?file=http://vidmg.photobucket.com/albums/v298/elite38868/MOV01863.flv"></embed>
Try the one below if the first one doesn't work:
