I’ve had poor luck with oil pressure senders. I had an OEM replacement type fail, and I couldn’t make it work with the hole drilled in it. I’ve had two Bosch senders fail also. The last one survived for about two months. This is all within just under 5 years and about 25000 miles.
I recently installed a slightly different sender from what I’ve read about on the site. It appears to be an unbranded version of a VDO sender. It was sold on Amazon by Mover Parts. The case style is the same as VDO and a couple other non branded versions online. It is a 0-100 psi 240-33 ohm sender. It is a two terminal unit. WK terminal wires to the gauge and the G terminal to ground.
I sketched up what I noted today from cold start through a long, hot drive. The gauge error is advertised as 5% of full scale.
