Interesting that this post should come up today, as I was just about to write one related to Magnecor wires.
About a month ago I installed Magnecor Electrosports 80 Ignition Cable SS25-200T, Metallic Inductance EMI Suppressed conductors, All Silicone construction. Resistance of wires with distributor cap included, contact brushed clean to spark plug fitting:
a. Cyl #1: 3.436 kOhms
b. Cyl #2: 5.140 kOhms
c. Cyl #3: 6.650 kOhms
d. Cyl #4: 7.140 kOhms
e. Cyl #5: 8.883 kOhms
f. Cyl #6: 10.019 kOhms
g. Coil: 10.088 kOhms
h. Meter Error: + 0.08 Ohms @ 70F
15. Installed new distributor cap, Brand: FACET, Made in Italy, P/N: 2.7481PHT
16. Installed new distributor rotor, Brand: Facet, Made in Italy, P/N: 3.7573/13RS
Now what is happening is I have a slight misfire at changing from 2nd to 3rd in low speed and usually when cold engine. The original wires from alfa (GTV6 1982) which are the BOSCH ones, all have 2.4 kOhms. My question is: would the mismatch of resistance with the Magnecor wires cause a misfire?
Namarena
