161 - 180 of 191 Posts
interesting ,
i mounted on my alfetta an alfa 75 1.6 gearbox.
Mutch better than alfetta gt '74 gearbox , but only the first gear is hard to engauge , not grinding but hard
On the 75/Milano 5-speed, first gear is synchronized from neutral, unlike the 105 & 115 cars. But it's got this extra spring in there (parts 34-36 in the diagram) to damp engagement for some reason. On my Milano it never seemed to work very well.
I don't know if the original Alfetta gearbox is the same, but if yours is from a 75/Milano then it has these extra parts and isn't like the 105/115 gearboxes.
1686565
Regardless of the spring mod changing it to a 2-5 syncro assembly (has to be from a transaxle as syncro design is larger on the inside diameter) results in a far better shifter. Why did they not just do that from the start, and not waste $$ with a different junk design?
I've wondered that myself. The Milano setup is pretty gimmicky, and it seems like all you'd need to do is get another of the long #21 pieces and install that instead.
Alfa was just weird about first gear on all these cars for some reason.
Probably because thats how Porsche did it.
Maybe, but Porsche design engineers were not Italian. Never had problems with my 3 911s shifting from neutral to 1st???
  • I just found one gear box like mine for really good price, so I will use for spares and I will do the 1st gear fix in the best combination.
I know it's an older thread, but I am rebuilding my '78 spider gearbox and need parts for a first gear fix and a second gear freshening as the synchro ring has a groove worn into it and the dog gear is missing three teeth. thanks, Patrick 928-288-0457 or patrickinpayson@gmail.com
at some point in the very near future.. were are you going to get new parts for this 60 plus year old gearbox?
I realize I'm two years late to the party, but I'm working on my Duetto's gearbox and have made the first gear fix. The sliding lock at the bottom of the picture is a replacement, and I've replaced the dog tooth ring (obviously). I'm a little concerned about the sliding lock though--it seems a bit small. Before I button everything up can someone let me know if I've got this together correctly and if the lower sliding lock will work ok?
Alex
Alex
Which synchro rings are you using?
Your box would have had non moly rings originally.
The moly rings use slightly larger quadrants.
Hello.
Thank you for idea and detailed instruction
I made 1st gear fix on my Spider S4, no crunch now. Wonderful.
But sometimes it is very very difficult to choose a 1st gear. No crunch, but I can`t insert lever in 1st position - it resist. When engine is off, everything OK, so this is not a wrong assembling.
Is it OK?
From "neutral" with the clutch "engaged" the gear are turning. If the syncro and gear are not meshing simply engage into 2nd
then engage 1st. It`s a common issue where the new syncro assembly is not well broke in and friction is higher. You will find it getting easier with use.
The bi-directional syncro is more balky than the old 1 direction original synchro design, due to a slightlt taller center .
The early syncros are harder and the center raised area taller. I polish a minute amount off of that center rise to resolve some of the initial balking (from having to compress the ring deeper to allow the teeth to engage.)
Thank you, Richard , for deep explanation - now I am calm. (y)
To anybody who wants to answer :).
Why does 5th and Reverse gear have the up and down syncho/locking mechanism of 2-4 gears? You cannot change down to 5th gear, so if Alfa Romeo were cost cutting with 1st gear why didn't they cost cut with 5th gear?
This question doesn't matter, just thinking ...
I think the better question is why didn't they ever just fix first gear? The additional cost was, what, one extra piece? And why didn't they put the transmission through some sort of mass-reduction program to improve shifting and reduce synchronizer wear? It seems pretty clear that the transmission is plenty strong, and a bunch of metal could have been removed from the gears without compromising performance.
You want to know why the Japanese car industry clobbered everybody in the '70s and '80s with reliability? A focus on quality and continuous improvement, which is something Alfa and other carmakers really lacked.
"It's good enough, learn to shift right" only gets you so far in the market, lol.
