Burman steering box
203 views 12 replies 8 participants last post by  Fiffen
Hi. I’m putting together a 1300 GT junior that I didn’t take apart. Lots of surprises. One is a cracked steering box case. I found a use with solid case and the races are not pitted. I thought that I read everything about these boxes, but the ball bearings are of different sizes. Forward and rear bearings have 7,1mm ball bearing, but the worm gear has 7,9mm. The groove/race is wider too. Forward has 10 balls, rear 13, but the worm gear has 26. I just want to be sure that I have the correct amount? Has anyone here on the forum experienced this?
#2 ·
Welcome to the BB DouglasJet, that is an absolutely beautiful Junior and an exceptionally clean garage...
Is your steering box the Burman or ZF one and I presume LHD ??
Ciao
Greig
#3 ·
Balls should all be 9/32”. I believe 54 in total.
#10 · (Edited)
So Doug, have you answered your own question? I have learned something as I have never seen such a Burman. Are you sure about the ball diameters as the boxes were built, as far as I know, in the UK so might be English units.
Ken
#11 ·
Sounds like there were some oddball (GET IT? :LOL:) Burman boxes out there. I wonder if there's any commonality in year those cars were built?
I'm sure the boxes are all English units. The standard balls are 9/32" (~7.1 mm) and it sounds like Douglas's box has a nut with 5/16" (~7.9 mm) balls in it. Here in the US they're both available from McMaster.com for not very much money but I'd assume they're a bit harder to come by in Europe.
