Re Input bushing:
The Alfetta engine's flywheel bolted directly to the driveshaft, with the clutch and transmission in the back of the car. In the 105 chassis, the clutch is on the flywheel with the transmission and its bellhousing right behind that. The input shaft of the transmission goes forward from the tx thru the splines of the clutch disc. Then it continues about 20 mm into a hole in the end of the crankshaft, to keep it all aligned. There is a bushing that is pressed into this hole in the end of the crankshaft that is made of a self lubricating stintered bronze for the tip of the tx input shaft.
Most Alfetta cranks didn't have this bushing, or the hole drilled to take it. However, some did, probably built from parts common to the other engines. If it had the hole in it, it was a no-brain swap. To put an engine without the hole in a 105 chassis, it must be drilled, and it must be done accurately or the shaft will vibrate wildly. It's easy enough to do on a mill with the crank out and nearly impossible with the crank in the block. If the car doesn't shake like a wet dog, they probably got it right.
If the engine was built as a carburated one in your country, it'll have the same CR as most other alfa engines. They adjusted for fuel issues with cam timing and ignition timing.
Robert
