Idle jets for emissions Webers
Here is a list of the idle jets that are used with emissions Webers. The outside dimensions of these idle jets are the same as the more common F1 - F16 range and the fuel orifice numbers have the same meaning. A 50F11 and a 50F22 both have a .50 mm fuel orifice. The internal bores are different. The early, common types have a single diameter bore which varies between different F number jets and ranges from 1.4 mm to 2.10 mm.
Emissions types have a stepped bore. The upper bore is always 3 mm and the lower can be 2.00 mm or 2.1 mm. The total area of the air orifices of emissions type idle jets is in a higher range than the early types. In other words, the richest emissions idle jet is leaner than the leanest early type.
F # holes Diameter
19 1 1.2 Rich
23 1 1.25
25 1 1.5
24 1 1.55
27 1 1.6
26 2 1.25
17 2 1.35
21 4 1.1
18 2 1.6
22 4 1.2 Lean
