Dear Forum,
The shift lever in my Montreal moves about a half an inch back and forth at the knob after you put her in first gear (and reverse) when just easing off the clutch and giving her gas. If you step back down on the clutch, the lever will move back. Everything else is fine.
The mechanic says that it's due to the shape of the hardened plate that the shifter spring touches. He further states that if the plate was the same shape as the fourth/Fifth gear selector fork plate was, there would be no problem.
So my question is, is all of this movement normal or can the blame for the moment be placed somewhere else? The tranny is now apart, so it's the time to do what's right! Does anyone have any experience with this?
The mechanic is a quite experienced 70 year old, licensed airplane mechanic with tons of Alfa and Fiat experience. But was never in a Monte box before. He thinks its a design flaw.
thanks,
John Pergolizzi
San Diego
thanks,
John Pergolizzi
San Diego
