Nord 2L. During my timing adjustment, I had a problem with the intake cam gear lock nut tightening by itself and then spinning with the crank when it was supposed to be loose as i was finding tdc on the crank pulley. I did not notice this until the crank abruptly stopped due to the intake valves hitting the exhaust valves. This happened twice actually. I did not try to force the crank past the sudden stop, but im wondering if the abrupt stop when turning the engine over might have damaged a valve. After the second time this happened i noticed my top end making an knocking or snapping sound when turned by hand. I figure if it makes noise by hand it will be more prominent when running. Can anyone chime in on this? See attached video for sound
