I am in the process of re-installing the front suspension on my '67 Super and have run into a problem. The new KYB shock does not extend enough to pass thru the upper perch. ... just touches. Earlier, I decided to update the brakes to the newer GTV/Spider ATE's (for parts availability) and swapped to the newer uprights/spindles as well. I now see these newer uprights are a bit taller (+5/8") than the old ones... which may be causing the problem. Any one else successfully made this brake swap? What additional parts do I need?
Also, I would like to "slightly" lower the stance. Any suggestions as to pros / cons of cutting 1/2 or full coil off stock spring length? Or is this just a bad idea? Thanks.
Charlie - SuperCC
'62 Giulia Spider
'67 Guilia Super
Charlie - SuperCC
'62 Giulia Spider
'67 Guilia Super
