I replaced the fuel tank, fuel pump, filter, lines, etc in a 74 Spider 2000. It sat for a few weeks and now I am not able to get it running. The car will start on starting fluid and run only runs until the fuel is gone. I have a fuel pressure gauge between the front filter and the injection pump which shows 23 pounds when the pump is on but the car is not running. When the car was last running it had 16 pounds. So there is fuel going in the injector pump. There is fuel that comes out of the injection pump and returns back to the tank.
Here is the problem. The is no fuel coming out of the top of spica pump. I checked the pump belt and the belt is not broken and is turning when I crank the engine over. What else should I check?
