Have any of you tried drilling a hole in the stuck piston and pull/prying it out? Right now I am stuck - cannot budge the piston to do a rebuild
Do you happen to know what size ribe is needed?very good point about cleaning out the calipers if you use the grease method, so splitting the calipers, new square cut O rings required etc.
The bolt heads are "ribe" head...best use a ribe tool or you will mangle them, and they are nigh on impossible to find
(of course you can use something else)
presuming front and rear have the same size bolt heads, thenDo you happen to know what size ribe is needed?
Okay, so that's another thing I don't think I didVery Important Pro Tip. When removing the caliper RIBE bolts, do NOT turn the ribe end. Loosen via holding the RIBE end steady with the correct RIBE bit (for a while there, front and rear were different sized but I think Alfa eventually went to a single size) and only turn/ loosen the NUT. Use Kroil or other favorite liquid wrench type stuff as well.
Which is hardly a big deal compared to ruining a caliper piston by trying to grab hold of it physically. Just drop the calipers in to kerosene, and you should be washing them anyway.Grease gun method works but is a mess to clean up
My guess is that's a holdover from when the internal seal was rather hard to find. I know I had a heck of a time getting some when I rebuilt my Milano calipers but that was like fifteen years back.And please can we stop the "must not split the caliper bollocks". Every brake caliper rebuilder just splits the calipers. There is the world's most simple seal in between the caliper halves.
30 minutes for both calipers? Not a chance. Nowhere, no how for quality work. I'm a mechanic and I dont -- unless its court of last resort -- introduce grease into hydraulic lines and assemblies. I;ve had to clean that junk up and I dont wish it on anyone. Using air and a rag is my preferred method. And you do you. If you like the grease route go for it.Which is hardly a big deal compared to ruining a caliper piston by trying to grab hold of it physically. Just drop the calipers in to kerosene, and you should be washing them anyway.
This thread is an example of where the internet is NOT the best place to get advice. A mechanic will have used a grease gun, split and cleaned the caliper halves, put new seals in and assembled in no longer than 30 minutes for both calipers
Who took the jam out of your donut, Pete?Amazing.
I'll stop talking as I cannot come up with anything constructive to say
I've used this on my Norton Commando motorcycle; just have to clean out all the gunk in passagesOn old, neglected caliper that have been static for years, I cut a brake line/or hose fitting, drill and tap it for a zerk (grease) fitting. Install it in the caliper and use a grease gun to hydraulically remove the stuck piston. This method is only need after lubing w/kroil and attempting to break the rust bond by working it in and rotating the piston with adjustable pliers as the grease technique makes a mess you must block the piston that frees up first to get the second to free up.
All good advice so far on various ways to skin a cat. But note from my reading of the thread that it hasn't been mentioned yet that the piston may be slightly c0cked in the bore, and jammed enough to not come out. Generally it seems the reason pistons don't readily come out is either corrosion or being c0cked a bit. You may have a look and see (if youre caliper is off the car) if the piston looks unevenly seated in the bore. If so, 'persuading' it to even with a vice grip C-clamp, ping the piston with a hammer and piece of wood etc may free it up. Spray some kroil, lithium grease spray or something around the circumference first. Just rebuilt the calipers on my Spider in the Fall, and one of the fronts was a little jammed. They are a pretty tight fit in there, though can get c0cked. I think mine got c0cked from a cheap ebay pad spreader--the spreader wasn't pushing the pistons back evenly. Calipers had sat for a year, so were likely not moving that great to begin with. Good news is, the ATE rebuild kits are easy to find. Pretty rewarding job. Good luckHave any of you tried drilling a hole in the stuck piston and pull/prying it out? Right now I am stuck - cannot budge the piston to do a rebuild
