I've been fighting pinholes in paint for waaay too long. I'd like a consensus as to where you feel they originate.
Logic is they are either in the body filler or are caused by water in the air line when painting.
I use two water extractors. One is near the 80 gallon tank, the other is about 40' away at the hardline air outlet. I keep both filters drained when painting and have the train tap on the compressor tank slightly open to let water out continuously. I'm seriously considering buying a Harbor Freight refrigerated air dryer. No, not saying it is the ultimate, but hopefully it will help eliminate any water problems.
I do try to carefully go over all of the filler to check for pinholes before applying primer, but do wonder if they can still pop through then in turn pop through the (single stage) paint.
My most troublesome areas are on the hoods and trunks (mostly Round-Tails so large trunks) which indicates it must be a water problem since the water is most likely to 'come out' when spraying a flat, upward facing, surface.
I'd sure like the opinions of those who've solved this problem.
Biba
Biba
