101 - 104 of 104 Posts
so I took the brackets to get them press and installed the compressor found a ground wire does that ground goes to the compressor or any were?
awesome found the bolt and nut on my cart now should the compessor kick non now or do i need to charge it first ? ? because when I turn on the ac the cluch doesn't kick on
Discussion starter · #103 ·
You got to jump the trinary switch wires to ground to engage compressor clutch relay to engage clutch until you have some R134a pressure in system. But you first need to use a vacuum pump to evacuate the system down first for about 30 minutes to check that system will hold a vacuum. Then you add the R134a. You better get the right equipment and know what you are doing. Did you install a new receiver dryer, R134a expansion valve and ester oil; etc... Did you read this DYI FYI A/C guide book? R-134a Conversion Guide
