..on the 'liners' i have removed a few heads..20-30 of the buggers some easy some.. i never mover a ' liner off the block. ... i used the rope trick.. and found it the easy way to do it... but before you do that.. all the bolts off? yes.. spark plugs in? yes..good.. now spin the motor over with the starter.. the compression will lift it a bit..it's not the gasket giving you troble,, it's the studs giving you trouble.. after you spin the motor,, lower the 2 and 3 pistons to the bottom.. thread in a lot of 1/4" nylon rope.... turn motor over by hand..is it lifting? after you get the head up a little get some wood scrapes and stuff them below the head on 1 and 4 this will allow you to lift the head off, , and if it only goes up a little bit, the wood will stop it from coming back down on the block, lift the head, insert wood.. repete... soon the head will be off the block.. after you have the head off the block, get some of those brass rifle cleaning brushes.. stuff on in a drill , and go at the holes that the studs go into in the head.. nice and clean..it will make it easyer the next time.
