1979 Alfa Romeo Spider Coolant Temp Sensor is not working
1.8K views 2 replies 3 participants last post by  fedegi
I noticed the Coolant Temp gauge works when the motor is turned off. Any ideas on what the issue could be? Do I need a new temp sensor, could it be wiring? If a new temp sensor is needed, any photos of where to swap out?
Thanks so much for your help.
Debbie
#3 ·
I'm a bit curious about this behavior. It looks like some temp gauges have a resting position in the middle, other (including mine) rests at min, like the gas and oil gauges. Can you please do the following test, with a cold engine:
1) switch on the power (no need to start the engine). Temp gauge should go to ambient temperature (around the minimum)
2) switch off the power
Does the needle stay at min or returns at middle? If it returns at middle, it means that the resting position is at middle for some odd reason.
But I bet that it stays at min, It means that the needle developed friction on its axis that prevents it returning to rest. This woud justify the difference between gauges (temperature gauge stays in the same position during driving, the others float).
