123 distributor installation
2 reading
6.3K views 12 replies 8 participants last post by  otteud96
I must admit I feel pretty stupid, but this has me stumped. Due to continued starting issues, I decided to swap in a 123 distributor and a new coil. Look at the picture. Cylinder 1 is at TDC. Top right plug wire is #1. Why is the rotor way off? I guess it's been way too long since I worked on my ignition, but I'm clueless as to next steps
#4 ·
I had the same issue the Position of the rotor is irrelevant you have a New # 1 once you determine TDC/ cam marks and you pulley, also start @ 6' advance static.
#8 ·
You can do it, we are smarter the the dizzy. The rotor position throws everyone for a loop. As previously stated once set make sure your wires (plug) are positioned correctly, 1 to 1, 2 to 2 and so on, and set up for the rotation of the rotor. Once installed and running, set the timing at max advance and enjoy!
#9 ·
Couple of hints
1. be careful handling the nut and washer that hold the dist to the block. It’s a bit fiddly to remove - reinstall. Remove the dist cap and rotor to install the washer and nut
2. Make sure that the o-ring on the dist shaft is seated in the recess on the block . Don’t forget that oring.
3. when you drop the new dist shaft down into the hole, rotate the rotor while pushing down on it. There is a key way that needs to engage — you will feel it kind of “clunk” in place and you will no longer be able to rotate the rotor.
You CAN do this! Go get em!
Reactions: .382780
#11 ·
Couple of hints
I definitely really appreciate the tips!
Couple of hints
Couple of hints
I really appreciate the tips! And the motivation! Now I just got to figure out what I should tackle first... the distributor and ignition coil or the strong gas smell coming from the trunk. Regardless, thanks again for your time and the tips!
