SPICA To Weber DCOE 32's Conversion Kit
Message
262 views 4 replies 2 participants last post by  Delllta
$2,850.00
Check price
Fairfield Glade, Tennessee
Latest SPICA Fuel Injection To Euro Weber Carb Conversion Kit:
Euro carb conversion kit (to replace SPICA FI), Spider GTV Berlina Italian Weber 40 DCOE 32's, disassembled, cleaned, media blasted, & inspected, new throttle shafts & throttle shaft bearings, most hardware new, jetted for 2L motor, new carb blocks, thermostat, temp sender, short & long throttle rods, comes with Euro carb throttle linkage, lightweight bell crank, carb support strut, correct 2L Euro manifold media blasted, new gaskets, new SPICA block off plate, new bypass hose, new Filter King filter/regulator, new Carter P4070 fuel pump, fuel lines & clamps, Euro air cleaner assembly (upper painted, lower media blasted, new straps & seal), and new air fitler. $2850 + Shipping.
#4 ·
Alberto,
The throttle shaft bearings are an industry standard bearing. I don’t have the number handy but I can get it for you tomorrow. I buy them in bulk from a supplier in Kentucky but just about any bearing supplier carries them.
-John
You have insufficient privileges to reply here.
