P/S Pump Rebuild Kits?
1.1K views 8 replies 6 participants last post by  Graham D
I know they were once available but cannot find the thread on here. My pump is leaking and I want to rebuild both it and my spare before things get worse.
What comes in them? Where do I get them?
#3 ·
G'Day Monty,
If you can't find a kit, this list was gleaned from a Japanese site:
Oil seal (inside diameter X major diameter X width in mm) 16X28X7 material NBR
O ring (inside diameter x width in mm)
10.5x2 NBR 6 required
36x2 NBR 1 required
17x2 NBR 6 required
28x2 NBR 1 required
#4 · (Edited)
Here's the thread:
http://www.alfabb.com/bb/forums/milano-75-1987-1989/2462-whats-wrong-my-ps.html
With the shaft seal and o-rings in hand it's a pretty easy job. Be sure to use nitrile or viton ruber.
Those dimensions for the o-rings are more accurate than the guesstimated ones in my old post, so I'll go back and update them. It's not clear to me what the 17mm ones are for, though - all I needed were the 10.5s, the 28, the 36, and the shaft seal.
#7 ·
No need to get the kit. You know the seal sizes, just order the appropriate parts.
Nitrile O-rings can be found at the link below or plenty of other places - they're dirt cheap. Alfa Parts carries the shaft seal, or if you want it cheaper just buy a standard oil seal based on the dimensions Craig gave.
O-rings Online Frameset
