hi,
get a small flat blade screwdriverand lever off the cover on the door pull,
there are two screws under there
then loosen the screw that holds the door lock indicator and pull it off,
then i start from the bottom rear corner and carefully stick the small flatblade screw driver between the door and the door card and lever it off, then work your way round the door popping off all the clips.
then lift up the door card off the window trim,
make sure all the clips are lined up properly and that the handle is lined up when putting it all back together....
have fun
simon
