Howdy... I'm a long time lurker, new owner of a 1974 2000 Spider Veloce. I've been following the conversations here long enough to know the basics and have tried to apply them since I bought the car in July 2016.
I have the Wes Ingram SPICA manual and Pat Braden Bible & Companion.
Things are great with the car (you can see where thing are: http://74alfa.com), but she burns a lot of oil. I'm trying to get a more exact measurement this tank of fuel, but likely 1qt / 200 miles. Probably more like 1.5. The SPICA pump is definitely a 1974 model because the thermostatic actuator that was replaced with a shop spare is too long when extended at 170 deg F. So I feel fairly confident it's the original pump and over 100000 miles.
I have some invoices for engine work in 2015 by Alfaman, so my assumption is that the pump cylinders are out of tolerance and letting oil pass in with the fuel? So, it's burning that much oil and spewing it out the tailpipe as well... this is expected unless I replace the SPICA pump with a refreshed one from Wes?
She runs great and I'm gradually getting her up to higher RPM in higher gears each week. I may be runner her lean, but I calculated 44mpg my last fill up. That was an increase from 19mpg the tank before.
