164 Suspension & Mount issues
1.9K views 10 replies 8 participants last post by  Alfissimo Int.
The sway bar bushings needs a little helps to compress them enough to get the nut started. I needed up using the swiss screwdriver to assist me by prying down a little on the top of the sway bar.
The dog bone big bushing is a pain. I used a dremel to cut the sleeve on one side to break its lock on the housing. Even with a 20 Ton press, pressing the new bushing in is a bit tricky.
