I need a bulb for my clock. Will this work?
1 reading
1.3K views 5 replies 4 participants last post by  alfaloco
I was searching the internet and saw this bulb at Oreillys auto parts will this fit and work?has anyone seen or tried this bulb?
The part info is
Part # 2721MF
EiKO Lighting - Light Bulb
1 year limited warranty
UPC: 31293052599
12V .1A T1-1/2 B8.5D Base
Amperage (A): 0.10 Amp
Detailed Description
Amps: 0.1
Base: MF Series (B8.5d)
Bulb: T-1 1/2
MOD in mm: 0.20/5.1
MOL in mm: 0.925/23.5
Volts: 12
Additional Details
Average Life (hr): 1000 Hour
Bulb Family: T1
LCL (In): 0.40 Inch
LCL (mm): 10.2mm
Light Output (cp): 0.48 cp
MOD (In): 0.200 Inch
MOD (mm): 5.1mm
MOL (In): 0.925 Inch
MOL (mm): 23.5mm
Filament Type: C-2V
#4 ·
To clarify (and if memory serves) its not the same as the dash lights. The dash lights are are an all-glass bulb that pop into a plastic twist holder in the dash.
I believe the clock bulb uses a panel-mount bulb, which has the bulb integrated into a one-piece assembly with a twist holder. It looks like that's what you're buying with the 2721MF: it has a 2721 bulb in a B8.5D base (panel mount, I assume 8.5mm hole size).
I can't tell you if the 2721MF is the same size as the one in the clock, however. It looks like it but I can't tell for sure.
#5 · (Edited)
what clock ar we talking about here?
the analogue (tick-tock with old fashioned hands!) S4 clock or the green display Borg clock?
The S4 has two bulbs it seems:
http://www.alfabb.com/bb/forums/1193010-post3.html
the digital clock (LCD) single bulb is discussed here and looks very much like what Tom above illustrates.
http://www.alfabb.com/bb/forums/940039-post10.html
whether they are actually the same bulbs I dunno....look to be from the back view of both clocks......never had the bulb/s out of my S4 clock to actually compare!
#6 ·
The bulb is the 2721, the smallest of the series I believe, rated 1.2 watts. It is not commonly found at auto parts stores, either, at least around here. There is another T 1-3/4 series bulb that is just slightly larger, a bit higher wattage, that won't fit the socket Gubi refers to. I know that because we bought a supply of the wrong bulbs for my son's GTV-6, and it turned out only the 2721 would fit the sockets correctly in the instruments. The wrong bulb actually expanded the socket slightly to the point where it would not fit into the base of the instrument, which is where our suspicions began.
Anyway... back to the clock. I hope you get the correct bulb, I was talking about the analog clock such as the one in my 1991 Spider.
