Greetings all; I’ve just started driving my new-to-me 1984 GTV6. I knew coming into it that not everything was working as it should be, so I’m trying to assess and make a list of items to fix. My car is a 1984 California model US-market car. Over time it has had some upgrades and some non-original parts installed. It seems like it had Tropic Aire A/C that was removed at some point prior to my ownership. I did not receive an owner’s manual with the car, and haven’t found answers to my questions via googling. Thanks for your patience!
Any ideas on the knob in the far right switch blank…right of the window switches? It has five clicks as you turn it clockwise, but doesn’t do anything that I can ascertain.
The labels on the HVAC sliders are confusing. If I ignore all the MAX, A/C, II, etc markings outboard it seems to make more sense. Am I correct in assuming the top one is cold to warm sliding left to right, and the bottom one is recirculate to fresh sliding left to right? The reason I ask is that I seem to get warm or hot air once the engine warms up no matter what, so I probably need to pull this unit out and see what’s going on.
I’m guessing the strange markings outboard of the sliders don’t directly describe the function of the sliders, but might suggest both all the way left for maximum A/C, and both all the way right with the fan on 2 for defrost???
Last question: what holds the panel that contains the fan and A/C knobs to the rest of the surrounding area? Someone ran two screws into mine in an attempt to hold it in, but they don’t screw into anything behind, so it continually falls out. I’m guessing it originally had some tabs on the edge that clipped in to the opening, and they have broken off? Any photos of an intact one are greatly appreciated. I searched on Google images and eBay listings, but didn’t find one that was clear.
