Depressurize fuel system
1 reading
1.3K views 4 replies 4 participants last post by  divotandtralee
#1 · (Edited)
A friend of mine was helping a newbie get his '82 Spider running (Bosch ) ( and my friend is a newbie to later Alfas like this). He was working on the fuel system and literally hosed himself down with gasoline at high pressure when he removed the tank filter. Is there a warning in the owner's manual he should have caught about a build up of fuel pressure and a walk through how to deal with it?. This is extremely dangerous. Does the Spica system load up like that too? I can't believe there isn't a thread on this. He said the clamps wre simple clamps not anything special to hold this kind of pressures. He said it came out like a firehose and caught him right in the face. Scared the hell out of him .
I found this on a web search https://itstillruns.com/depressurize-fuel-system-6119372.html
#3 ·
Pretty much every Bosch fuel injection system is designed to hold pressure in the lines between the pump and the fuel pressure regulator at shutoff, AFAIK. It's to help the car start up quickly after sitting.
If you have a mityvac hand pump, you can apply vacuum to the vacuum port on the fuel pressure regulator. This will relieve a lot of the pressure, but you still need to be careful when opening the lines. I pinch off the hose with hose pliers, disconnect the hose, and then release the fuel in a controlled manner.
Not sure what he was expecting from the clamps, but it's no higher than the running pressure (30-40 PSI) so good old hose clamps work fine. Though you should probably use the Euro-style ones as they don't have the holes that can cut into the hose over time.
#4 ·
Should not be a problem with the Spica system. It's a recirc system that maintains pressure through a small constantly open orifice in the outlet fitting of the injection pump. Soon as you turn the key switch off and the supply/boost pumps turn off, the pressure in the system very quickly bleeds through the open orifice and goes to zero.
