Dellorto DHLA-L...high idle speed
3.6K views 1 reply 2 participants last post by  Gubi
If you've got an emissions version you've got idle air bypass screws. I would check and make sure those are all closed.
They are basically only used after you do all the other tuning steps to fine tune the two throats of each carb. If they're open when you do your tuning they'll mess things up.
