How does one remove wire to O2 sensor?
2.8K views 4 replies 5 participants last post by  ianhudson1
I am replacing stock exhaust with header system from center line and need to remove wire from O2 sensor. Tryed pulling and twisting but the wire refuses to detach, any suggestions?:confused:
Paul
#3 ·
Yeah if it's the bosch system it detaches near the master cylinder, one plug for the two white wires and another for the ground. Removing the sensor from the down pipe is no picnic, I had to use a slotted box end 22mm (to get around the wire) some heat and some penetrating oil, then lots of cursing.
