I have just discovered the Alfa Montreal uses the ZF S 5-18/3 transmission.
I have one not installed in a Montreal, but my vintage Opel Ascona race car. Unfortunately, it is locked up except for 4th gear. Are there any Montreal owners out there who may have a contact for a transmission shop that has some knowledge about this transmission?
Rob
Can't help with a shop but I could send you the ZF service manual if you'd like. If so, please send me your email address in a private message and I'll send it to you.
Richard Jemison
ZF repair
ZF Has a US rebuild facility. I have a box with their sticker on it. Don`t know where it is but Google should.
If you're in LA, I bet Santo's shop in Northridge can deal with it.
Or in the Bay Area, Tom Sahines (ARA and AROC tech hotlines).
Rob
try the maserati biturbo... if memory serves, it uses a similar zf box. if not exactly the same i reckon the guts can be pillage to repair your ascona.
here in america people give these yuppie massers away or you can find a whole car in relatively good shape for peanuts in the wrecking yard
good luck
Yes, the Maserati Biturbo and Biturbo Spyder also uses the ZF S5-18/3 gear box. Be aware that later Biturbos from (I think) 88 or 89 has a different gear box. Also note that it's possible the gear ratios are different from the Ascona, but many of these gear boxes have the ratios written on a plate on them.
ZF made a large number of variants of the all round S5-18/3 box, and they may or may not be a drop-in replacement ratio wise ...
