ZF rack bush and parts advice required
899 Views 2 Replies 2 Participants Last post by  Ranz
(Posted this under tech forum, but without any feedback, so have copied it here..)
I am REALLY hoping that the last knock to be eliminated from my Alfetta GT relates to the bush at the outer (passenger) end of the ZF steering rack- ie the metal (later plastic) bush in the end of the rack housing. I have already done tie rods & ends, and the rack itself seems fine.
I have seen one-only ebay source, being from Greece, offering a plastic bush WITHOUT O rings. The usual suppliers don't seem to carry the bushes.
I'm looking for leads for suppliers, and hints, tips or traps...
Is there a kit available?
Are the O rings generic/standard easily obtainable?
Is there a separate seal inside the bush?
What about lubrication? I assume it would be smart to redo after 40 years. what lube should I use?
Thanks in advance...
you have a reply in tech forum
Thank you Sportiva. I have added a question in that same tech thread.
Moderator - would you kindly now delete this duplicate thread?
