Yokohama AVS ES100
1943 Views 16 Replies 9 Participants Last post by  Anfanuts
anyone have these?
1 - 17 of 17 Posts
Yeah, I've got 'em on my Spider. They seem to work quite well wet and dry.
I'm assuming you're not planning on driving in snow with them...that would probably be a bad idea.
The AVS ES100 is a good tire and seems well suited to the Spider chassis.
They are not the stickiest but have good breakaway characteristics and are easy to control when driving at the limit.
Joe
i heard that these tires are "loud" - according to tirerack recommendations.
just for good weather.
Joe,
What would you say are the stickest? I have them (205/60X14) on my GTV. When I bought them 4 years ago they were rated by tire rack as the best (and almost the only) high performance tire available in their size. What do I buy next?
Joe
Yeah, I read that too before I bought them. I haven't noticed. With the Spider it's probably a non-issue anyway as you get so much noise from the wind that you won't hear tire noise.
You are correct, in that 14" size the AVS ES100s do appear to be close to the only option for good high performance rubber.
For this very reason I moved up to a 15" wheel a few years ago on my GTV, and some S4 Spiders have 15" wheels standard. While the selection in 205/55-15 isn't great, there are several good high performance choices that would be stickier - including the newer Yokohama S.drive, the Toyo Proxes T1-R, and the BFG G-Force Sports.
Joe
good point since with the top down it is already noisy.
I think you can still get the Falken Azenis in a 195/60/14. I have a set of these for track duty on my non-Alfa, and I think they're fantastic. I reluctantly switched back to my all seasons yesterday. My Spider has the Yokohamas and they don't have anywhere near the grip of the Azenis.
-Jason
I think the Azenis are a great semi-track tire, and a *really* amazing value.
My only gripe with them is the sizes they are available in (195/60-14 and 205/50-15) are IMHO a little bit too short for 105/115 series Alfas.
Joe
Joe
That was the reason I chose the ES100s. I'm planning on putting in a 4.10 rear end next year, so I might opt for 195/60. I'll see how it goes.
-Jason
I've got the Azenis on two of my three Spider's, if that tells you anything about how much I like them. I did have a set of ES100's on one of them, with Azenis on the other, and it was no contest. I buy mine from Vulcan Tire, and still have a spare unused set.
i had fulda tires on my saab and loved them. i dont think they make them in the usa anymore. anyone have them on their spiders?
the old AVS had abit of noise but they wre just big chunks of rubber. the new avs es100 have no noise I can tell. I have then on both my cars. the old avs was like driving on ice if it was wet very very scary. the new avs es100 seem to stick almost as well wet as dry. and they seem to last when you push them hard vs other tires.
I have never used a Azenis but evey other tir I have used I hated compaired to the avs
Yes, had them on for a long time, they were, well, fine. I am unable to discern great differences in tyres but they gripped well and when provoked around corners they slid predictably and without squeal.
Spider Tires
I formerly had Michelin XWX 195 VR 75 14's on 6" (22 mm offset) Cromadora's and they handled and rode well. Just put on Yoki AVS ES100's in 185x60's and they are bone jarring by comparison. The car also sits pretty low and revs pretty high for same speed. I might have gone with 70's for street use. If you just cruise in a spirited fashion versus outright slalom think about ride quality. My mechanic says slalom enthusiasts put on Yoki Advan A460 in 185 60-14. Bruce
1 - 17 of 17 Posts
