1 - 2 of 2 Posts
Just starting to have a look around for a cam cover off an early 1750 or 1600 with the fixing bolts at the front unlike the early 1600s. I am also probably going to need the air intake housing and cover for the crossover. Any one got some spares collecting dust?
Hi,
I wasn't going to sell, but...
I have the air intake box that mounts to the webers, and the cover, and a ratty flex pipe, and the air filter housing. The cam cover is exactly as you described but is bolted to the engine so will be hard to post. I'd need a non-dipped cover to replace mine (with the same front bolts and rear seals). All metal work is in decent condition, the flex pipe works but looks as old as it is.
Shipping would be expensive I guess. It's all from a series 1 1750 GTV.
The photo is from when it was mounted but it's under plastic (not collecting dust) in the garge now.
Did you have a price range in mind I don't know what they're worth?
PM me if you are interested and we might work something out.
1 - 2 of 2 Posts
