JJ,
I was just about to give you a buzz on some parts that fell into my lap. I will give you a call later.
I did thanks! Would you please email me via [email protected] about any of the other pieces that you might have for me? Thanks! Or, buzz me at 425.941.4747. I don't need any 12 valve blocks or heads thanks - just the parts listed above!I got too many engine partsProbably a front cover, pickup tube, etc. Did you get all the liners and "S" piston?
Are you looking for the thermostat or the lower part that bolts to the water pump?Just refreshing this inquiry. Also - please note that my email and phone numbers have changed...
[email protected] is a good email for me personally and 425.949.9518 is the best phone number for me.
As always, the shop here at Group 2 Motorsports is always a great way to reach me as well - the website is Group 2 Motorsports and the shop number in Seattle is 206.378.0900
In any event, what I am looking for currently are as follows:
1) From 12 valve 164 B / L / S models – especially from the EARLY deep-sump models - it has the two bolts hidden behind the crank-pulley;
- Front front engine covers - the covers that hold the front engine seal (where the crank pokes through the block – right behind the crank pulley…) 2-3-4 of those please, if you have some. Any number of covers please.
2) From ANY of the 164 B / L / S models;
- 1 Set of engine cam rockers.
- 2 known-good power steering pumps (or rebuild-able cores - please define)
3) From any 12 valve GTV6 or Milano models;
- Thermostat housings – SPECIFICALLY the types that have the neck of the T-stat pointing towards the right-front corner (US-models passenger-side) of the car…
- Oil-pump pick-up (just the head with the screen on it) - 2.5 or 3.0
- Flywheel - 3.0 Verde/Americano (or from an SZ Zagato) specifically!
4) From any Alfetta (sedan or Coupe);
- Complete pedal-box with hanging pedals and brake booster (or I'll use a booster from a late-80s Spider.)
Thanks!
The lower part that bolts to the water pump...Are you looking for the thermostat or the lower part that bolts to the water pump?
If you want the one with oval outlet facing right side of car (passenger side on LHD) that is the Milano one.The lower part that bolts to the water pump...
