there the slip in style , the shorter the better.Any particular length you're looking for? Are you auxiliary venturis cut to accept the slip in style?
Keith
Alfas unlimited
Gary thanks,but i can buy them new off ebay for $70(all 4) also, Im jus looking for a good used set that someone has that wants to sell.
Keith makes a good point. Original Alfa Webers used an airbox and filter, and the auxiliary venturi's were different, fitting flush to the front face of the carb, which means you can't slide the trumpets in, unlike most other applications.Any particular length you're looking for? Are you auxiliary venturis cut to accept the slip in style?
Keith
Alfas unlimited
If you do have these original aux. venturi's, than your options for stacks are :-
bolt-on ones, that utilise the mounting studs already on the carbs, or
get rid of the original aux. venturi's and substitute ones which accept the "slide-in" stacks.
Alternatively, if you are running aftermarket (such as 40DCOE 151's), or a Tipo which has been previously fitted to another make of car, you would be likely to have the aux. venturi's thgat accept stacks.
Hope that helps.
Steve
The spring clips do get deformed and lose their grip though.
Steve
