Bob and Andy, first let me say that I have run a total of
one lap in the 2:41's at Road America. But my point was that I didn't run out of revs with the 4.77 with that lap time. Peter Stark says he runs about the same revs with a 4.55, but then he is faster than me. He was in the 2:40's at the last event. Of course I blame that on weight. Our cars each weight the SVRA minimum of 2000 pounds, but I weigh 265 and Peter wouldn't way half that dripping wet! Well, okay...he can also drive!
As Andy pointed out, the GTA could end up as quick, even with the smaller motor. But I doubt it would hit similar top speeds. That is more limited by aerodynamics and horsepower. So what kind of power is your 1600 making? If I were in your shoes, I'd be tempted to run the 5.12 for now and see how it goes. You can always put a 4.77 in it later. If you must have it now, you may want to buy an OS Giken one for a 2L style diff. Of course if you have already bought the Gripper LSD for the early style, that wouldn't be an option. Or, if you have the early diff set up for a sliding block, it might not go right onto the later style diff.
As for Watkins Glen, I don't remember running very high top speeds there. On the front straight, I was just getting into 5th. And the long uphill pull toward the bus stop didn't get me near redline in 5th.
Erik
Bob FYI, 2.41 @ RA is the fastest time I have ever seen for a Alfa GTV/GTA body on treaded tires. More common is 2.44-3.05 lap times. I know the GTA is lighter, but top speed will likely be limited by HP vs wind resistance. I believe Eriks car had a lot of fiberglass (light weight) and was making 167hp at the rear wheels when he did the 2.41. The GTA driven well will make up it's time under braking and 3 wheeling through the corners!
