No, they should be two speed. But on most of them the speeds are “slow” and “slow”
They should park themselves. This requires the foot washer switch to be both present and working properly. You can jumper two wires at the foot switch connector to see if that’s the problem? I think you connect the two blue-white wires: if you do that and it parks, then the foot switch is bad.
Lemme check tomorrow to confirm how I jumpered mine.
