1 - 5 of 5 Posts
Need nozzles for 1993 spider. Please reply if you can help
Brad
I see that IAP has them now. I was searching for "nozzle" . No hits. "Jet Spray" finds them thanks
Brad
don't tighten them very much
Brad
Brad,
When you install your new ones, be very careful and don't tighten them very much. They have a real tendency to snap off with anything more than a couple of ft-lbs torque.
The curved spring washer (that goes between the nut and the cowl cover) should apply enough tension to hold them in the direction you set them, but they should be loose enough to be twisted by hand (to "aim") from the top side of the cowl cover.
1 - 5 of 5 Posts
