1 - 9 of 9 Posts
Can anyone recommend a place in the San Francisco Bay Area that would be able to help me re-assemble my windshield (for 63 Spider) back together nicely? I've gotten the windshield posts chromed, and am now ready for re-assembly.
Thanks.
Any topless bar will do. You just need another pair of hands and common sense to assemble everything as a unit before you drop it onto the car. It's like framing a picture. Bottom first, then sides, then top.
Patrick,
One important thing is to make sure that there is no paint in the sockets for the windscreen posts. I cleaned mine out and the posts sat at least 2mm lower and positively compressed the rubber seals between the posts and the body. I coated the socket inner surfaces with copperslip to protect them and to allow easy rotational movement of the posts when dropping the assembly into place.
I also bonded into place the vertical rubbers and made cut-outs in the back face to allow them to sit in the curve at the base of the screen. Other than that, and a bead of sealant below the bottom rubber, it dropped into place and bolted up beautifully.
However, a pair of hands from the topless bar may not speed up the operation but may well make it more enjoyable.
See you in October.
hey pat,
Bob at Franks in Berkeley put new rubber on my windscreen... he did a great job.
Can I have Bob's contact info.? I'm actually coming up to Glenn Oliveria's on Wednesday to drop off some stuff.
Is Frank's a topless bar? Nice! :D
no, Pat it's not running yet... I was going to put another 1600 engine in it, but have now decided to rebuild the original engine with some high compression pistons...
1 - 9 of 9 Posts
