1 - 2 of 2 Posts
Hi,
The window mechanism on my 1600 GT Junior broke. I bought a replacement and have installed it today it’s fairly tight around all the pulleys but I’ve managed to get it on. The mechanism from where the handle turns and spins the wire is incredibly tight when operating - the effort needed to turn it is far bigger than usual.
I’ve had a look at all the pulleys and the wire sits correctly the main thing worrying me is with the wire is sitting properly in the grooves of the window regulator itself. I’ve attached a video below but any help would be greatly appreciated perhaps it’s a small fix of some lubricant/grease.
Cheers
Giles
Hi I replaced mine on a 74 gtv and it was a bear to get it right try loosening the nuts that hold the regulator in place to see if u can get some wiggle room
1 - 2 of 2 Posts
